hi i gave my gn a tune up changed wire,plugs,coil pack,oil,map,tps it ran great then i hit the gas hard then it started to stall i got it home and it stalled again when put in gear it idol low i give it gas it run let it go it runs low and stop i put code read on in code 22,23,24 came up i checked everything what should i do next thank you
