PsychoBuickBoy
The Money Pit
- May 25, 2001
So I get home today and shut my car off. I go inside open my garage door then go back out and get in my car. I flick the ignition over and the starter engages and will not stop. I quickly turn the car off and the starter is still going! I frantically pop the hood and grab a pair of plyers and disconnect my battery. I reconnect the battery and push it into the garage. I look under the car and remove the flywheel cover. Thank god my flywheel is not chewed up. I try again to start the GN (with the ECM unplugged) and the same thing happens. The starter won't disengage once it is fired up. So I again disconnect the battery. What is up?
Is it an ignition problem or starter?
By the way, got the 72's installed and the car was running awesome!
