There can be many different ways of doing thing to our cars that generally get us to the same place. Verifying oil pressure is one of these items. He is my opinion and method.
Let me first say a normal rebuild is a "couple" thousand dollars. I refuse to short cut a procedure as important as verifying oil pressure for a few extra minutes or a few dollars for a priming tool, and maybe ruining a motor.
There are many people that say it does not hurt anything to crank the motor and see if oil pressure comes up. Since metal-to-metal is what ruins bearings and they MUST have an oil film to survive, I refuse to do this. If it is my motor, or someone else's, there is too much at stake.
The '86-7 turbo Buicks have the easiest oil pump to prime by using the cooler lines. Take a drill motor and priming tool, run oil pressure for a minute or 2 [or more!]. You can also see if there are any leaks at this point.
The info on the GN list was provided by someone that has his way of doing the operation. You are not going to hurt the water pump, but the bearings??????????
