Jun 30, 2002 #1 J JUSTAV6 Getting High On PSI Joined May 27, 2001 Messages 223 What Is The Best Way To Fix The Slop In The Tilit Sterring??? Thanks For All The Help, Seneca Lafler,
Jun 30, 2002 #2 G Geoff87 Administrator Staff member Joined May 24, 2001 Messages 2,817 Fix that tilt steering slop!
Jun 30, 2002 #3 Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Messages 16,628 Column loose?? I just looked at the GnTTYPE directions for tilt column repair and see ITEM #2 is NOT CORRECT!! As I recall, the "plastic cover" does NOT get "pried off". It gets the screws removed. Pry it and it's JUNK!!! RIGHT OR WRONG???
Jun 30, 2002 #4 J JUSTAV6 Getting High On PSI Joined May 27, 2001 Messages 223 That Helps, Thanks Alot, Seneca Lafler,
