Well I finally got my passenger side header off, which was cracked pretty bad, and had it welded. I replaced the oxygen sensor while I was at it. I fired up the car and let it run for awhile and it seemed like it was running pretty good. I finally went ahead and plugged my laptop in. My BLM was around 109 at a hot idle and it was throwing a code 45. My previous problem was the BLM pegged at 150. The car also seemed to be running better than before. I decided to disconnect the battery and reset the computer (again). This time the BLM slowly creeped up to 150 again.
The car also appeared to be running how it always did. Also, When I unplug my MAF, the car will run for a second or two then die unless I keep my foot on the gas. I thought the car was suppose to run of the default parameters. I'm not sure where to look next. My car is stock, with a 87 ECM, an authentic 87 MAF and a stock 87 EPROM. The car also ran like this when I had all my stock 85 components it it.
Thanks,
Rob
Thanks,
Rob
