turbodiesel6_6
- Sep 30, 2008
To make a long story short i will try and explain everything thats happening, i was having what i believe was an intake backfire going into boost, so i talked to Eric from turbo tweak and he recommended 42lb injectors, i replaced at that time also the injector harness, and hotwired the fuel pump and put in a walboro pump. With the fuel pressure set at 43psi with the line off i got the back fire before 10 psi of boost, more like 7, so i turned up the fuel pressure a little more to 46psi with the line off, got a little more boost 12 to 13 psi before the backfire. So then went to the translator and turned up the wot adjustment to 6% rich, no i can get to about 15psi without a backfire. My problem is, it doest feel like the car is pulling that hard, my Duramax would smoke it at this point. The car has a little over a 100,00 miles on it. I hear what i think is ticking comming from the passenger side valve cover, but havent opened it up yet. Brian from Gbody parts told me it could be valve springs weak or timing chain. Not that im disbelieving that, but if thats true wouldnt it be a good idea for a rebuild? I live near Columbus Ohio, and im not aware of any buick turbo engine builders around, i just dont want anyone inside this engine! Maybe someone here has some ideas and some advice for me... everyone in the buick community has been awesome... thank you for keeping this great vehicle alive with info..... i just wanna be happy with the car, all ive done is work on it the last two years to get it to this point. I will try and get some scan readings off of the car while warm, but the last time i scanned everything looked awesome. Sorry this post was so long, and thank you in advance!!!
