What i'm trying to find out though is the actual ohm numbers of the stock plug wires so i can compare them to the Bosch plug wires sold at Autozone which measure out at 2.890 per ft on the 20k setting,that was the highest reading i got in the set.
Hi Mike,
How are you doing? Did you get the fuel pump issue worked out?
I did. Lines have been upgraded -10 feed, -6 return with both pumps wired 'on' full time. If the weather holds out this weekend, I'll see how it all works out.
