Jun 30, 2010 #1 S srmcclean New Member Joined Oct 26, 2002 Messages 3 Hello, does anybody have the specifications for a stock GN cam including duration at .050, LSA, and intake lift and exhaust lift. Thanks
Jun 30, 2010 #2 K KL Mallender Certified Dumb**** Joined Apr 16, 2007 Messages 532 As I remember....Int 193 @.050 .390 lift at valve, Ex 197 @.050 .411 at valve, cam was ground on 107 centerline. Kevin.
Jun 30, 2010 #3 S srmcclean New Member Joined Oct 26, 2002 Messages 3 Thanks Kevin, I actually meant to post in the engine tech sections
Jun 30, 2010 #4 B broke86gn Member Joined May 30, 2010 Messages 111 stock cam specs Stock cam data from a vendor's catalog: Advertised Duration : 258/262 Duration at .050" lift : 192/196 Lift .384/.408 Lobe Separation 107 degrees Overlap 38 degrees
