Stock cam specifications
srmcclean
Hello, does anybody have the specifications for a stock GN cam including duration at .050, LSA, and intake lift and exhaust lift.
I like that, The lift/duration values are different from the info I have though but the rest is the same. My info has the lift at .410 in .420 exh on the stock cam. And 196/194 Duration
the data from gnttype.org is correct:
Advertised Duration : 258/262
Duration at .050" lift : 192/196
Lift .384/.408
Lobe Separation 107 degrees
Overlap 38 degrees
ML
