Nov 23, 2008 #1 V v62go Member Joined Oct 19, 2008 Messages 260 i want to go to 83 lb injectors need to know what to do ecm wise chip wise and who's the best to do it,Thanks........
Nov 24, 2008 #2 D DailyDrifter The Slow and the Curious Joined Dec 5, 2007 Messages 5,118 you need to get the ecu modified to run low Z injectors, Turbo Tweak can probably burn you a chip.
Dec 1, 2008 #3 6 65malibuss Member Joined Dec 8, 2001 Messages 222 How about 79 lb? Turbo Tweak sells high impedance 79 lb injectors now.
