gnmaster2004
 - Mar 4, 2004
It went 10.12 with the 6266ok that makes way more sense
SignUp Now!It went 10.12 with the 6266ok that makes way more sense
For those that want to try this9.87 @ 134 single 525 pump
We put the squeeze to dynoman car when it was on the old comboI didn’t log any data
I’m still running the stock computer . I need to upgradeWe put the squeeze to dynoman car when it was on the old combo
Duty cycle on 120s was well over 90% nearing 100 with boost in the 35+psi range.
It did it
but....there was no cushion and the conditions were good.
His car is an little heavier.
We had more pump it was not a 525 he had more fuel sytem than injector.
It was on a stock computer with a very small correction window.
Upgraded the computer and decided from a safety factor to go bigger on the injector to get that cushion back![]()
Are you on 120s?I’m still running the stock computer . I need to upgrade
YesAre you on 120s?
Yeah your at the end duty cycle wise.
