Hi Tim,
man it's hard to tell you about all that little junk but I'll try.
1- IAC hardly used. $25
2- New a/c delco knock sensor. $35
3- MAT sensor used. $10
4- New a/c delco PCV valves. $10 each
5- New hi - low relays $15 each
6- New a/c delco brake pressure switch Used for testing and removed. $50
7- New a/c delco delay - relay. $50
8- New a/c delco TPS $35
9- Used but good waste gate solenoid. $45
10- 9 new hood pad pins. $10 for all 9
11- New energy suspension polyurethane  bump stops. $15
12- 2 new lower body bushings with bolts and washers from Kirbans. $15
13- New Heater blower motor relay $15
14- Heater resister. $10
15- Nice used and one new FPR little L shaped vacuum lines. New one is chrome. $10 each
16- New a/c delco left side dual window switches with bezel. $25 each
17- 87 Power steering cap. $10. White lettering is mostly wore off
18- Two new rubber T/L and back up light gaskets. Left and right. $25 for all
19- New 2 way and 3 way vacuum valves.$5 each.
20- Just about any small gaskets you might need.
22- New cork 20 bolt pan gasket. The good one. $15
23- New GM rope style front timing cover seal. $5
24- New GM rubber type front seal. $5
25- New Felpro cork valve cover gaskets. these are the good ones. $25
26- New 3 bar map sensor. $35
Sorry dash cover is gone but still have the driveshaft. also still have 2 and 42 for you.
