You ran a stock cam to 6400 rpm?
Maybe you should list your current mods then go from there. Budget some money for tires. No sense making that kind of hp and not getting to the ground.
Ok here is a list. I have done the trans and some minor tweaking only!!!
all else was there when I picked up the car.
Ported heads with larger intake valves (with tape masure looks about 1 3/4 inches) exhaust looks about 1 1/2 inches. I had the heads flowed (looking for the sheet) but I do remember thinking "thank god this thing has positive manifold pressure otherwise I could get out and run faster." Ports dont look that bad either.
cam of unknown specs, has grind numbers on the sprocket end but have no clue what specs are.
turbo looked stock, worn everything but stock
mechanical adjustable wastegate
3in downpipe
coated crossover tube
looks like rewelded stock manifolds
big 10mm plug wires
test pipe/no cat
flowmaster mufflers
ported upper intake, found cracks from too much anger during reinstall
green stripe injectors (42 1/2 I think)
Billet adjustable regualtor, set to 44lbs i think
duttweiler intercooler necks
what look like larger intake ducting to innercooler and engine
dont remember but I think someone touched up the lower intake with a die grinder.
some adjustable thumbwheel chip
a plug in volt booster
plug in fuel pump upgrade
heated o2 sensor
plug in tps booster (dont like it seemed to run better without)
some kind of come-along engine to frame tie down thing
eibach springs looks lower by 1-2 inches not sure
bilsteins on all 4 corners
centerline big-n-littles with old rubber (will replace soon)
extra set of centerlines with mt et drags (newish never really had a chance to run them)
driveshaft loop
turbo 400 with 485 stright cut gears, kevlar bands and clutches, early 400 sprag (the one with the addl rollers bearings) hughes deep alum trans pan. The 485 gears are really cool, they sound like a roots supercharger, add that to the sounds of the turbo and the car sounds darn neat goin down the road or at wot.
Has a 10in 3k stall converter also from hughes
And yes the car has gauges, boost, oil pressure, coolant temp, tach, knock alert, and rich/lean.
line lock
That is all that comes to mind.
I found some poorly installed parts and some poorly adjusted parts after I started to play with the car. My run down the track I ran a shameful 14.2 (mph unknown.) Tried different methods got down to 14.0...... I then did some homework and a friend and I adjusted the tps (way off) cranked the boost from 13 to 15/16 psi, adjusted the floor mat and ran low 13s all night long. I did find a time slip that said 13.2 at 108 with a 2.1 60ft so I may be off on my mph, still havent found the 13.0's, must be hiding from me. I am also going off of 4 year old memory Bison, wouldn't suprise me if I find out I am wrong. I do know the 13.0 and the 2.0 numbers are fact however. I thought I remembered the car pulling to past 6k on the tach with the car falling on its face around 6400 or so. I am pretty sure I am wrong as I just looked up the chip info and the rpm limit is 6k. I feel kind of dumb guys sorry. I do know that with street tires I would leave the light at about 2500 and the tires wouldnt light up until 3500-4k. I would just keep my foot in it as I would loose boost if I tried to feather it and go slower. That is what I found, not sure if i was driving poorly or not but what the heck, I was having fun.
The car was kind of a pos, rode hard and put away oily. It only has 92k but I found after the CLEAR COAT started peeling that the car had not 1, not 2, not3 but 4 coats of paint and some skechy body work. Oh well it is in the process of getting reworked/repainted. Luckly the coats were thin and are coming off easy. Had I known that the engine/trans/turbo and wiring were in such poor condition I may have picked a different car, but live and learn. I have dump trucks of money in this thing and have a few more trucks to go before all is said and done.
I plan on suspension fun and a beefier diff.
Sam Colalillo, these are the rods I picked up.
http://www.turbobuick.com/forums/parts-sale/269066-oliver-billet-6-off-center-narrow-rods-new.html
Thanks again guys! Hope I didnt put you all to sleep.
