Stock Headgasket thickness?
86 TR
Work In Progress
What is a stock headgasket compressed thickness? .040 or .060? Im going to be buying some RJC gaskets and wonder how much the compression ratio will change with these stainless steel gaskets.
Thanks.
I just installed the RJC gaskets. With about 10 thous off the heads & deck already to be nice & flat & the RJC at 40 thous I had to take 40 off the intake for it to line up perfectly so watch that when doing the installation.
SIX,,when you say 40 thou did you cut intake 40 thou each side
Yes & some have done up to 45-48 thous with more off their heads & I could have gone 41-42 but 40 is working fine for me.
Ditch the end seals (too fat now) & a big bead of Right Stuff sill seal it up.
