Just installed a walbro fuel pump, hotwire, adj fuel pressure regulator and fuel pressure gauge. Still using stock injectors. What should the fuel pressure be set to?
If you have an after market chip most use 43# as the base setting with the vac line off. If you still have the stock oem chip 36# is where it will need to be.
