stock motor knocking at 12psi
EyeTalk2Trees
I have a completly stock motor, (see sig) and I get knock at 8-12psi. I know the gas here in west texas sucks, only 90 at the pump, its also 90-105 everyday. Even when its a cool 70 outside I get knock in closed loop. When the motor is in open loop I don't get knock. Also is my knock sensor out, because when i say i get knock i can hear it in the engine. This is the only GN I've riden in and the only stock one I've seen. What is normal on these hotairs? When i add octane booster it helps but is there something ele i can do? I raised the Fuel pressure to 40 with the line off, it runs better but the knock is the same.
first thing
first things first keep your foot out of it till we (turbobuick members) help you fix your car. i have to run or i would start helping you out i will post later
brent
I'm sorry every that has helped so far, I talked to conely and they were suppose to put a chip in when i had them do some work but it some how got comunicated wrong and they didn't. I looked at the chip and it doesn't say anything just has a orange or red sticker on it. is this the stock one? if it is I'm back to my problem, if it isn't I'll have to find a stock chip cause thats the only one i have.
thanks for helping
i'm still having trouble with the knocking. I haven't been pushing it, but i still wonder what kind of knock sensitivity do other hotairs deal with.
thanks
