Will this work? I have a stock unported plenum with egr passage intact. My new setup has egr disabled. I don't have the funds for a bigger tb and plenum at this time. I am using the egr block off plate from Kirbans. I don't think the champion intake even has the surface that mates up to the egr passage on the plenum. I was just going to trim the plenum gasket. Will it be ok to use the power plate I have for the stock plenum? Maybe at the least I will try to cut out the egr passage of the plenum. If I do this, should I mod the power plate or just go with out for now? Thanks.
