First off this is your opportunity to do one of the most effective conversions for these cars. That being an electric fan. The belt driven fan is not very effective and takes up alot of space that can be used for other mods. The stock radiator is also to small and ineffective. There are many ways to do this, examples are "F" body radiator and an oil cooler, if money is not a concern, "Be Cool" has some of the best options. These will have oil and trans cooler already and are aluminum, They are very light, but very expensive, also the 87 GN radiator and fan will work. I have been in the dual fan nightmare for a while now, and I can help you avoid many of those pitfalls. A single fan conversion is the easiest way to go with a thermostatic controller. The reason behind the thermostatic controller is that the Hot air cars even with the 87 ECM conversion are not wired for electric fans. You will need an 87 wire Harness. With that in mind if you don't have an 87 harness stay away from the racetronix dual fan harness, I have one it is useless for my needs. also don't buy anything from "Durales" I got that one and it was completely misswired. Had the main power wired directly to the secondary fan terminal.
As for fans, I finally had to go with the Flexilite duals, They fit well, and depending on the radiator header might mount directly. Mine of course did not, but with a bit of creativity I was able to mount it. They only draw 19 amps and will run on one relay. I have the permacool controller on order but as with everything from jegs it is backordered.
Basically what I am telling you is beware advice given by 86/87 owners it is not the same car by any means. And unless you have converted to the 87 ECM and more importantly to the 87 Wiring harness, any advice about this mod will just frustrate you and cost money.
My setup is this...."F" body radiator and mount, flexilite 220 dual pullers, permacool Wiring Kit w/Prode Thermal Sensor, and although with the flexilite it's not really necessary, the permacool 30-Amp Relay for dual fan operation.
