Stock Radio Question
g_wilson
I have a stock radio in the 87 GN, the concert sound version. The Front RH speakers have some sound coming from them, but at a very reduced volume level compared to the other 3 speaker locations. I swapped the Front RH and LH wires in the harness going to the radio and the speakers on the RH side are working correctly so it is an radio issue.
Is the amp for the Front RH channel blown or is there something I can do to fix it. I am comfortable taking the radio apart and using a soldering iron to replace components if necessary.
Thanks,
Greg
Hey Greg, I'm having the exact same problem. I have replaced the stereo with another stock one. It worked for a while, now its doing the same. I can hardly hear (if not at all) out the right front and door. If you figure it out let me know.
Dave
