Tim Cucci
- May 24, 2001
I have a spare original engine that I would like to put back together. A 10/10 GM Turbo crank to be used with stock bore pistons and rods and block. All are original to the block. Only thing new or different is the stock turbo 10/10 crank and bearings.
#1 Has the rotating assembly absolutely got to be balanced for stock rebuild.
#2 Can a CAT neutral balance flex plate be used to balance and run with this engine. Or do I just need to find another GN original flexplate?
I have everything original except the flexplate.
