Stock Throttle body rebuild
spross86
Hi all does anybody sell the shaft bushings/seals? Looking to rebuild my Stock Throttle body for 86GN
If your throttle body has never been rebuilt, the gbody seals are on the very tight side when installing. Check the shaft for end play, the housings are known for having too much wear. Without correcting the actual issue, seals only can be a band aid repair. Good luck, hope the rebuild goes well!
Thanks Turbo! No issues with the Throttle body I am powder coating the body so I have to remove the seals.
Thanks for the heads up.
