Stock Turbo vent...???
psycho6cyl
Ponies Are For Lil Girls
I am going back to a stock turbo and i already have the breather bypass done.. what do i do with the peice off the turbo?
Normally people just plug the port that is on the side of the inlet bell. You might be able to use one of the rubber plugs that is typically found in the Help section at Autozone. Most vendors that sell the passengers side breather kit will include the rubber plug that blocks off the inlet bell port. Make sure you clamp that rubber plug as well.
HTH
Patrick
TA 49 inlet bell.
could i use Kirbans inlet bell for the 49 on a stock turbo?
I would imagine so, it is the same turbine housing, it may be a little bigger at the connection though, do to the larger turbine.
,Dan
for a stock turbo, yes, a kirbans inlet bell will work. i have one on mine. though, if i were you, id just port the stock inlet bell, and cap off the oil tube and be done with it. i think smoothing the stock bell, and radiusing the stock compressor housing is worth more, than just boltin on a kirbans inlet bell and being done with it to tell ya the truth. its free too :)
