buickman69
Retired Buick Enthusiast
- Dec 2, 2001
I've done a lot of searching and found threads from, 15-10 and 3 years ago but what I am looking for is a sound confident answer.
I've put these 1.65 roller shafts on the car and I'm torn on which way to go. For several months its been sitting in my shop covered up with VC just sitting over the drivers shaft covered by new rags but not bolted down and new rags covering the passenger shaft.
My biggest concern is leaking. I'm sick of this car enough already but oil leaks and having to do it all again is my biggest fear.
These are original iron Buick heads worked by Champion.
An old friend who has 40 years worth of turbo Buick parts (wants me to buy it all) I visited a few months ago. Brought home a set of GN1s and they are still in the plastic. I just don't like the way they look.
I've had someone tell me there is a thick enough gasket that I can buy to put on the stock VCs that will seal.
I've read of the adapters from RJC leaking, I've even read of all the aftermarket raised VCs leaking.
I've already bought from Champion and opened the package, a new set of cork gaskets for the stock VCs.
Then there is another issue of bolts. I was scatter brained that day and didn't get the bolts with those GN1 covers and he is 2 hours away.
So what do you do with the wastegate solenoid that mounts to the upper right bolt/stud of the passenger side VC? Does the bolts that come with the RJC adapters have a stud on top for this solenoid in the stock location?
I like the stock look, but leaking is my number 1 concern!
As far as aftermarket VC I'd rather have an aluminum color Buick Motorsports VC, or just say Buick, or even with the Buick Tri-Shield logo would be cool (no Jiffy Lube logo) but I don't think they exist raised to clear these rockers.
Guess I'll pull the freaking motor to do this. Beats spending all day wrestling, cussing and busted knuckles dealing with no room on the passenger side.
Just need some help here making a decision.
Suggestions and real world experience appreciated.
