- May 24, 2001
Why does our stock wastegate Act. have 2 vacume ports? I was wondering this, and I removed the hose from the port closest to the passenger side, and then plugged up the vac port up at the throttle body.
When I tested it...removing the line gave me about 2more psi of boost, and the turbo spooled up faster....are there any downsides to keeping the port open, and not applying Vac to it?
or is this one of those things that we still ask GM "What were you thinking"?
Thanks for your help!
FYI FYI...if anyone does this make sure it is the port closest to the pass side..if you remove the driver side then your car will have umlimited boost, and it will blow up!
