I decided to do some logging the other day as I wanted to see what the car would shift at on its own on the 2-3 shift. I was also trying to see what kind of drop in rpm I was getting on the converter lockup. Anyway, when I was close to the top of 2nd, it shifted to 3rd for a second, then went back to 2nd and then finally shifted to 3rd again for the last time. You can see the strange behavior in the log. I have included screen shots in the attached document. It all happens in a matter of a second or two. It isn't slipping into gear at all either. They are positive shifts. I haven't tried shifting manually yet.
The tranny has a ck servo and one of his older recalibration kits. Also, I recently installed a new pump assembly from Dave Husek in the hopes of curing a wot lockup issue, which it did.
