Strange shifting
Swede2
I dont know anything!
I have a rebuildt tranny on my TTA. It has only went 138xx miles.
Strange thing that it was needing a rebuild at this time... All the rear clutches was burnt.
Well... My tranny mech said that: you shall not spend much money on this ****ty tranny, shouldnt you ?
I: Hmm I dont know, its not a regular TH200, they say that its stronger...
He dosent think its a good tranny. The converter is also vibrate little, dont remeber if it was so before the rebuild or after.
What can happen when I have vibrations in the converter ? Is it bad for the tranny ? Also have same problems as before the rebuild, that the tranny dont wanna shift up when Im in the 2-3 gear and put the gas pedal down and then take it up at part throttle... It will lay on 4-5000 rpm for a long time, without shifting.
Is it only to adjust this on the TV-cable or can it be another problem ?
Daniel
