I had a deal fall through and have a nice trans to sell.
It has all Alto clutches and band, transbrake, 694 servo, 10 vane pump, bigger boosters, hardened drum and input shaft, and many other parts as well. The switches and wiring are set up for a GN black plug, and it has a new lock up valve. This unit slightly differs from my normal build in that it was built more for a mid-high 11 second car in the way it shifts. (a little less aggresive) It does not have the "case stretcher" servo my other units have.
This is a Monte SS core, set up for 3.73 gears (I could change this), as mentioned earlier, it has all the correct wiring for a GN install. This unit will provide slightly higher shift points than the BRF, and should come in at 5300-5500 rpm.
Price is $1250 with no core needed. Very good trans for the $$$!
Please email me at hipsibri@cs.com
Thank you, Brian Hofer
