Stretch slic shroud and stock driver side bracket wanted
In search of a shroud for what I believe is a 15 row accurate fabrications stretch slic. Also looking for the stock bracket. Prefer an aluminum shroud, or some kind of tin, or will modify stock to work.
This is the intercooler.
If you don't find a used one, GN1 Performance sells a nice aluminum stock replacement that can be modified to work.
Make an adjustable bottom plate that bolts under the sway bar.
I know it's a little spendy to buy just to modify, but it seems the norm for my car anyway.
http://www.gn1performance.com/products.asp?cat=110
I bought a 3.5 maf pipe from Full Throttle just to cut/ rotate the filter end clockwise 1/2", weld, smooth, paint and shorten so it worked with my TA49, 85mm maf and KB ram air set up. But then again I like to run weird stuff.
