Hey guys. Finally pulled the trigger and bought my first TR(been dreaming for 10 yrs, and lurking here for quite awhile)......love it so far. Even when it's broken! Kinda heavy to push around though:frown: Please help me fix her!
My first disaster is a destroyed rocker shaft. A bolt sheared off in the head and it cut loose. The shaft(solid) is damaged so, since I couldn't find another, I'm going back to a stock shaft with the RJC braces. We removed the broken bolt from the rear pedestal but hit a wall when installing the new shaft.
The center mounting hole(different hole than broken bolt) in the head is stripped out. When we removed the old shaft, I noticed that the center bolt was longer than the others. I figure it was a prior problem and I just destroyed what was left when the bolt snapped and hell broke loose in the valve cover. As soon as torque is put on the bolt it pops right out. These are iron heads.
What are my options? Can I safely tap that center pedestal hole another 1/2" or so? If so, do you think that would be enough?
Thanks guys....all opinions welcome!
-Jeff
-Jeff
