If you can't get a secure wrench on the rubber hose side and you are committed to replacing it... Cut the rubber hose so you can put a 6 point socket on there. Flare wrench on the steel line side did not work well for me, it would not budge. For some reason it came loose really easy with a pair of channel locks. If the fitting gets mangled you will need to cut the old flare off, replace the fitting and flare the line.
Sent from my iPad using Tapatalk
