Stud size
gnloyalty877
t'squick6
I'm wanting to use studs with nuts instead of bolts for my turbo to thdp connection and i need to know thread size, length
I have a 3/4 thick flange on my THDP. The bolts I am using are #8-1.25mm and 35 mm long. If you want to go with studs and nuts you will need to go longer. Probably add 10mm to the length and you should be fine.
