Vac should be more than 4-6
I bet you have a really bad vac leak...is it idling really high?
No it idles like complete crap. It idles at like 850 900 and it is rougher then driving over rumble strips on a road course.
SignUp Now!Vac should be more than 4-6
What is easiest way to do this? Stock intercooler etc.Time to pressure test the system. You have a large vac leak somewhere.
If he had a large vacuum leak wouldn't the blms be much higher?
I will check that tomorrow when I swap out regulator.Check the intake manifold bolts. mine had loosened to almost finger lose at the egr area and that caused all kinds of idle problems. I retorqued and its been fine ever since.
Have you pulled the valve covers and looked for a broken rocker or pushrod or valve spring?It does not have boost solenoid or any egr stuff. The screen at maf is clean. Pcv is hooked up hose is new to it. When it is running pcv seems to be jerking like it is opening and closing when idling.
