Stumped.........Pt 2!!!
DaJoker
DUMB QUESTION MEMBER
Found my problem, vacuum line is loose but it is inside the car. The line goes into the firewall on the drivers side by the brake booster. Can anybody tell me where it goes before I pull anything else apart? :D Prolly a stupid question but if I knew the answer I wouldn't be asking.
Possibly goes to the climate control? The vents are switched with vacuum pressure.
Does that have the vacuum line to the cruise switch at the base of the column like the buick?
I can't help you but I bet Julio( Razor) has the answer.
