stupid air box question
Did you remove the elbow and the nut holding the cap down? If so give it a wack with a rubber mallet. Disconnect the mas air from the housing before hitting it.
Most of the guys have replaced the OEM filter & probably forgot how it comes apart, including me. If I recall correctly you can remove the elbow like previously mentioned & take it apart that way. I think the bolt goes through to the bottom of the filter & you can feel it if you reach underneath the filter.
Good luck
~JM~
It has a long bolt going though the filter. I'f I remember right you can access it from the bottom of the housing.
