This may sound stupid but depending on which lb injectors you have, that controls how much fuel is injected along with the ecm/maf. So if you have an adjustable fuel pressure regulator, wouldn't you just have it opened max all the time? What would be the point of closing the regulator if the flow is controlled by the injectors/ecm/maf? I know there's a rookie answer here I'm just not thinkin of it.
