May 13, 2008 #1 C cabech984 Member Joined Jan 28, 2007 Messages 486 What subframe connectors fit under the TTA's? I dont wanna buy anything that I'll be sending back! Do regualr Single cat tpi ones work or what? Thanks for looking Chris
May 13, 2008 #2 R Razor Forum tech Advisor Staff member Joined Jul 31, 2001 Messages 13,391 They all fit, the problem is aftermarket downpipe clearance on the passenger side front of the SFC. I had the old SSM ones.. some use the global west variety.. and they say that one has the best clearance. HTH
May 13, 2008 #3 1 1 quik6 Member Joined Mar 7, 2007 Messages 219 Don't buy the bolt on competition chassis ones from summit. I was not impressed with the install. Would definately try something else next time.
May 13, 2008 #4 G Grumpy Thread killer Joined May 24, 2001 Messages 13,815 Global West was used with your downpipe :wink:
May 13, 2008 #5 C cabech984 Member Joined Jan 28, 2007 Messages 486 Grumpy said: Global West was used with your downpipe :wink: Click to expand... Sounds good!! Thanks! Hopefully they'll "Mesh" real nice with the alky:biggrin:
May 13, 2008 #6 J j13smiley Member Joined Jun 21, 2004 Messages 582 mine did get welded in... but rubbed too much... here you can see the new section of exhaust that i had replaced after my sfc install...
May 13, 2008 #7 W WS6 Sock Monkey racing Joined Oct 29, 2007 Messages 526 I put on BMR's BMR SFC009 BMR Boxed Subframe Connectors for outside frame-rail exhaust, 1982-92 F-body Hardtop - SFC009 BMR Fabrication this past winter and had plenty of clearance.
May 17, 2008 #8 L Lynn D. Brown New Member Joined Oct 24, 2004 Messages 148 I got mine @ Fast Eddies', and they just make their own on your car. It ends up being cheaper.
