Sump Extension Kit.
2 questions for you Chris. How much fluid does it add and are there any other mods needed other than changing the filter, gasket, and then bolting it on?
It doesnt add enough capacity to be important but allows the filter pickup to point down towards the fluid instead of against the valve body.it requires a special insulated wire terminal end to connect to the fourth pressure switch and it is included.
I'll be sending money to you then. Make it out to ckperformance or to you?
