Sure flow pump pressure mod
Razor
Forum tech Advisor
Staff member
Does anyone have any information as to the pressure unit on the pump and its modifications?
DMan,Steve Hill...you out there :D
Julio........I like you. I'll help. There's a screw up there on the pump housing. You can turn it to increase pressure. And to turn up the boost, some guys won't tell you, but I will... turn in the rod on your actuator. :D
Saw that little allen screw..I ASSUMED it was for this..I'll hookup my pressure guage and calibrate it to NINJA death pressure :)
Hey John..what happened to the caps lok..this is so unbecoming of you.
Julio
Regarding the pressure couldnt you just turn the screw all the way down and get the max pressure ~100 psi?
Screw the screw..bypass that mofo and get 200 PSI :D
Dont ask how I know this ;)
June 2003 thread :eek:
And John no longer uses the Caps Lock :D
Seemed relevent. :p I'm looking specifically for the setup with the pump being perpetually lubricated while submerged in a mixture of denatured alcohol and klutz oil. Can you give a brother a heads up? :cool:
That's the old style smc setup which hasn't been produced since 2004-2005
pump is a Chrysler minivan piece
what else would you like to know?
