i have a 1984 Ttype when you keep it in third gear or under a load you can feel a surge i have replaced fuel pump,coil pack,wires,plugs,had it hooked to a scanner everthing looked ok also has a different air mass on it so i thought maybe the injectors my friend had set of 91 cad injectors that i tried car ran but didnt want to start after you drove it but rhe surging was still there pulled injectors back out any ideas on the surging and can the 91 cad injectors out of a small v8 can be used
