SignUp Now!Originally posted by geno
I had to fix the instant center problem i had from lowering the car. After i fixed that and put a wolf bar in i went 1.36 60ft
What Kevin said is true, i started out in 2 second 60ft range and 125 to 130 mph range before getting it right!!!Originally posted by KEVINS
ViciousV6,
It's not necessary to go coil overs. Good stiff springs and HD rear shocks are all that is needed. Remember, that when you start raising/lowering your car it changes the angles of the control arms and thus changes the Instant Center (IC) of the suspension. So if you spend a lot of $$ on lowering it to get a better 60' then you should understand where the IC is now and where needs to be for your application when you're done. You could go slower
ks
