Suspension mods to run mid - low 11's consistantly
d0n_3d
Boost is good.
Just wondering what else I need in the suspension area to help me run mid to low 11's...I already have air bags in the coils and slicks...everything else is stock...I have the combo to run the times but just wondering what I need to do to help with traction and such...should I box my lower control arms? rear end is stock and so are the shocks and sway bar...larger sway bar?
90/10 drag shocks, and ATR rear sway bar to cancel the roll of the 90/10 shocks. ;)
Here's what worked pretty well for me:
Moog coils
KYB's all around
Boxed stock LCA's with camaro rubber 1le bushings
bone stock uppers
ES poly body bushing kit including GNX bushing
Rear seat braces, front V braces and under rad cross brace
ATR swaybar
2 airbags, I found that setting them @ 9psi DS and 22psi PS was the magic #'s for me.
best 60' of 1.55, with tons of high 1.5's and very low 1.6's which will easily get you mid 11's.
best 60' without any air in the bags was 1.67 I think.
I still use my front swaybar, although I cam going to try it next year without to see if there is any improvement, and my car handles and drives very nice IMO. Hope that helps.
