swapping to TH400
FastRegalWE2
Wish I had another Buick!
about what does it cost to get a 400 built that will hold 600-800HP and what all is needed to swap it into the car. I wouold do the install/removal so only labor would be tranny build.
Contact Eric @ Dynotech. He'll take care of ya'. Great guy to deal with----(908)-704-8536
Originally posted by chris718
www.ckperformance.com the correct helix 2.75 planet,steel hub,and pro brake are not available elsewhere.
how more to add the lock up option? what else do I need to buy besides a trans and conv to swap? How will boost affect the vac modualtor on the TH400?
I don't think you want a 400 unless you are happy with non lock converter, 3 speeds, and reverse manual valve body (no modulator required....)
in other words....race only (or mostly.....)
I was just informed about the manual VB stuff, I saw the option fro L/U but I bet thats big $$$$
guess Im stuck with the 2004R for now.
At least I have a fresh CK SG2 one, just need a good TC to go with it
thanks azgn
I don't think you are "stuck" with the 200....they can be made very reliable
good luck
that didnt quite come out right, I just dont want to burn up another one,
But I do have CK to work with and Chris has been great so far.....
no complaints there
