SignUp Now!PhilM said:... or you could just get a transbrake and shift her! : )
No, 12 bolts have different pinion lengths, longer I believe49-blues said:Would the 400 driveshaft also be the same length for a 12 bolt housing vs. a 8.5 rear? Is there any more info on the mechanical modulator? Does the mecnanical modulator also use the 4 pin connector like the 2004r? Doesnt both trans use the tv cable irregardless of which modulator you use?
PhilM said:The 400 does have a vacuum modulator but you can get a unit like i had - called a "mechanical modulator" where it works just like a 2004R's TV cable. they are < 100bux
thats what im in the process of doing... with my th400PhilM said:... or you could just get a transbrake and shift her! : )
