Syclone pump??
6SENSE
Put together a completely stock hotair car for a daily driver. Fuel pump is weak. Since Im not going all out with this one but wouldnt mind a slight upgrade I bought a Syclone pump. AC part# EP381 from AutoZone. Besides its an instock part and the TR pump is not. However the #s on the pump itself dont seem to match anything that Ive found including a search here where someone posted the #s on theirs.
#s stamped (in the metal) on mine if Im reading correctly is: 25167997, 0654-207. Also has printed the number 992 just below the outlet nozzle on the white plastic.
Does anyone know if this indeed indicates it to be a Syclone/Typhoon/TTA pump? Wouldnt be the first time I got the wrong part in the right box, if it isnt.
Might just return it and go with the MASTER (#E3270) version for a few bucks less with a better warranty if I dont find out for sure on the ACDelco. At least I have been able to verify that one.
Also anyone who has run this pump, did you add the "extender pipe" as directed at gnttype.org for using the pulsator since the pump is slightly shorter than the TR? Or just go with a length of rubber hose and forget the pulsator?
Lastly, which strainer do you use? The part# for the Syclone or for the TR??
TIA
Sorry guys/gals, didnt mean to start a second thread on this here. Just found out. This one was supposed to be in the General Tech section. Moderators feel free to delete
