my85grandnation
85 Triple Threat
- Mar 12, 2004
I just went and had the brakes redone on my 85 GN they needed everything since somone had put an oil based substance in the master cylinder and it ate away the rubber hoses and everything else in the system that was rubber and then gunked everything up from the calipers to the master cylinder. The only thing that wasnt replaced was the hydroboost system because it seemed to work fine. When I was leaving the brake place the peddle seemed a little hard but not bad, when I stoped at a red light everything seemed normal but when I went to start up the pedal wouldnt come up. It stayed down. I had to reach down and pull it up. I took the car right back to the brake place and had them start looking it over. They said the power steering fluid was a bit low and that theyed check everything else out again. My main question is does anyone here think that the hydroboost system is failing now or was it just cause the power steering fluid was a bit low?
