I already know what the symptoms (FOR ME) would be for too loose of a rocker arm. mine started clacking loudly (one #3 exhaust arm) after I got on it on the highway, as soon as I let off the pedal, clak, Clak, CLAK!! all the way for about a mile on my way home. I took the covers off adj. the exhaust rocker, it was loose- I just snugged it on the pedistal mount rocker and locked it down.{I have no feeler gauge, Ive done this last year and was fine} The bee hive springs looked good ..... Put every thing back together and drove it for about 2 days rode smooth.
Now Im getting the horrible buck at 45, 55 mph. I get on it, it goes away. I try to start cruising it bucks again.?? cranks up and idles fine, no backfiring while driving at all. Just the surge or bucking is the best way to describe it.
Thought it was the plug wires, changed them to new ones, unplugged the tcc solenoid; same thing,.. changed the ignition module to a new ac delco, spark plugs doesn't look wet or too bad. Changed the coil pack too with various ones that I have.. All it does is just change the rpms at which it starts bucking again.
Is it possible that when I adj. them the lifters had bled down and later then somehow I have the push rod a SMIDGE too tight keeping it opened too long or something? That was the last thing I done but it shouldn't have rode as good as it did for 2 days if it was that, I was thinking. I thought it was bad gas but I filled up at a Chevron station where I always do. but thats what it acts like bad gas or a bad spark plug wire. No engine codes are showing up.
I haven't taken that cover off but would that be a symptom of a loose or I meant too tight a push rod adjustment? Thanks guys in advance.
And sorry for my typing illiteracy.
