i just started using the stageright brake and cut some 1.5 1.6 60's
leaving with 15 psi.
the only thing is the front tires get yanked off the ground, i'd like to stop this from happening, what do i need to do?
im still running the stock GN suspension with poly bushings and adj drag shocks. and air bags
when should i start to worry about breaking an axle? mine are still stock and have about 6, 15 psi t brake launched on them.
