T&D 1.65 Roller Rockers
Not yet. I look into TA and T&D to see if I can find anything.
Measure the length of the shaft. If they're 11.90" long I'll buy them
Shaft is 11 3/4. That is using a tape measure not calipers. Not sure if that works for you. Just let me know. Thanks
Actually, that is very helpful. Your rockers are probably 11.722 which is the length used on production iron heads. GN1 aluminums need a shaft length of 11.90". Using a tape measure, the length would appear to be right at 12" if they were set up for GN1 heads.
Thanks for the information. So it sounds like these are production irons and will not work on champions or aluminum.
You are correct. These are for production iron heads. Good luck with the sale. CT
SirVeyor , I think we all learned things here, thanks for your time on this . Gd luck on sale.
Thanks. I did learn. Hopefully you find a set that works for you. Thanks
