T&D Rocker shaft modification
getchasum
MISSING 2 CYLINDERS???
I have New Set of T&D shaft set up for a set of big valve stock iron heads. Im looking to upgrade to the Champion R aluminum heads. Who can modify my shifts and rockers to fit the champion head?
Tks?
Scott
Rs are 14 bolt and cant use a shaft style rocker , you need either chevy style scorpion or T+D jesel
I just finished a motor with the Champion 14 bolt aluminum heads. Attached is a picture of the rocker setup.
