T&D Rockers for S2 heads
Mike E
Mr. Badwrench
I'm going to put Jesel's on my heads so these are no longer needed.
These are not a matching set. There are two different styles of rockers here and both require different length pushrods. One style is straight across the top and the other has a step in the top.
If someone wants all of them I'll let them go for $130 for all. Otherwise, $60 for the straight top set of 6 "S" rockers with shafts and spacers. $60 for the stepped top set of 6 "S" rockers with shafts and spacers. And $10 each for the two "L" straight top exhausts and $10 each for the 2 "S" stepped top intakes. All prices are shipped. I will also consider trades for a fairly new set of ARP head studs for stage 2 heads.
All the rockers in the picture are "S" or 1.64 ratio.
Both of these exhaust rockers are "L" or 1.58 ratio
I will also include the hold down hardware also with each shaft setup.
The 6 stepped top rockers and shaft assembly are sold. The straight tops and shaft and all spares still available. Make offer.
Bump I'll split these up any way you want. Just let me know what you want and make an offer. I'll let them go cheap. I need them gone.
How about $50 for everything thats left. That's 10 rockers, the shaft, spacers and hold downs.
